torque sizing for ball valve
we are new to oil company, our sales threw a question to me regarding .we are need torque valve. 1.) NPS 16, class 600, Trunnion ball valve, seat material Nylon, manufacture valve cameron type: T-31. what might be the approximate breakaway torque ? 2.) What will be the approximate torque for Actuator?
RE: torque sizing for ball valve
You don't want to be breaking valve stems though, so there is some liaison required with the valve manufacturer.
Cheers,
John
We asked Cameron but he did not respond. We need torque of valve. Could you please help me about it?
How can you help me with it?
Best regards
Any valve supplier should have this available, something is failing in communication here! Alternative: if you can find out which actuator the supplier would offer for your valve, this is listed with torque tables at the factorys homepage.
If you search this forum for 'torque' you will find comments of how much torque can vary, depending of a number of fluid and operation conditions.
It will also be dependent on the seat design of the valve, floating seats require different break-away torque than fixed seats, but as mentioned above, many factors need to be taken into consideration.
Carry out breakout tetsing to the valve, this would consist of pressuring valve and recording required torque to operate, run and close the valve and vice versa. As your valve is of considerable size it most likely that this would only work if you were to use a norbar 9,14 or equivilant.
From the torque figures you obtain you would multiply this value by your required Factor of safety (usually 1.5 for XV and 2 for ESDV, SDV and BDV's) when you have done this you know have the minimum torques you require your actuator to output to suitabbly fit the actuator to the valve.
if you still can not aasatain the valve torques then you can look to use previous manufacturers such as TK as they are known in th indusrty to have high torque values in comparrison to other manufacturers.
thanks
D
