Link to a file whose name is specified in a cell
I'm trying to type in a file name and then link to it.
='path'[file-name]sheet-name'!cell-reference
I'd like to type in the path, file-name, sheet-name and cell-reference in adjacent cells and have the formula work.
Is this possible?
RE: Link to a file whose name is specified in a cell
Concatenate I do all the time, I have not used "Hyperlink".
I'll give it a try.
You don't happen to have an example, do you?
When I use Hyperlink, it places a hyperlink to the other worksheet but it does not retrieve the value from the cell.
You want the INDIRECT() function.
Indirect seems to only work when the child worksheets are open.
I get #REFs in each cell even though the concatenation makes an identical string as that created otherwise, when I navigate to and click on a cell in an open child worksheet.
Brackets, Exclamation Points, Apostrophes and all.
Perhaps more explanation is needed.
I have 20 separate worksheets whose file names change, call them children.
I want to make a summary worksheet, call it the parent, that displays and works with 10 items of data from all the children.
The children worksheets change names for each project but they themselves are clones so the cell addresses within each remains the same.
Some children are XLS and others are XLSX ( does that matter? )
For the first child, I typed in one set of references then copy/pasted the rest.
Then I used copy/replace to change the filename of the rest and Excel wanted to verify each and every link.
Very tedious, so I figured I would create a list in the parent, naming each child and then concatenating the file names to make a fully qualified address.
This is discussed at length at:
http://dailydoseofexcel.com/archives/2004/12/01/in...
which includes a post from me with a link to a spreadsheet with some alternative solutions:
http://interactiveds.com.au/software/getvalue.zip
There is a UDF (Pull()) which works like indirect and is the simplest, but is very slow for more than a few cells.
There are also some macros which work faster, but need to be updated with a button click.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
