Rafter to exterior wall connection
Do hurricane clips replace the need for tension ties when rafters rest on top of exterior wall top plates and attic floor joists run perpendicular to the rafters?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Rafter to exterior wall connection
As a P.Eng. you can use any system you can show will work, so possibly is the correct answer.
Again, this depends on the design and what the thrust is. With a ridge board, I doubt it will work, but you cannot say that "by inspection"...
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
Pretty hard to comment on that level of detail without the full set of plans.
Yeah. It still makes your scratch your head and wonder why they would ever frame the joists in the opposite direction. I'm curious more than anything. Keep us updated Tony!
Make sure this gets done right- don't count on things to just "work". It looks like maybe you can use the plywood sheathing for a diaphragm if it is continuous?
