Questions about hardness test on metals. Please...
I´m a newbie on the subject, so I need some answers. Please?
How is related hardness metals with its structure, grain size and composition?
How can I modify the hardness of a metal?
How must the surface be to perform a hardness test?
Thanks, I really need HELP !!!
RE: Questions about hardness test on metals. Please...
You're really asking the members to teach you metallurgy 101. Why not try to study the subject first and then ask a little more focussed question?
jp,
mcguire is correct but maybe we can whet yuor appetite a lttle.
copied below from your query:  with INSERTS
WHY DO YOU NEED ANSWERS?  JUST CURIOUS?  OR DO YOU HAVE A SPECFIC PROBLEM?
ALL OF THE ABOVE.
PURE OR ELEMENTAL METALS WORK-HARDEN BY COLD WORKING (COLD MEANING BELOW THE RECRYSTALLIZATION TEMPERATURE).  THE HARDNESS IS MODIFIED TO SOFTER BY ANNEALING.  SOME METAL ALLOYS ARE SUSCEPTIBLE TO HARDENING BY HEAT TREATING.  FOR EXAMPLE; QUENCH AND TEMPER AND SOME BY SOLUTION TREATING AND PRECIPITION HARDENING.  AGAIN YOU WILL NEED TO DO SOME READING TO UNDERSTAND THESE TERMS.
SHOULD BE A RELATIVELY SMOOTH SURFACE BUT TYPICALLY NO PREP NEEDED EXCEPT IN SPECIAL CASES AS NOTED IN A RECENT THREAD RIGHT HERE.
WHY DO NEED HELP?  ELABORATE!
Jesus is The TRUTH
If your interest is in the arena of "Non-ferrous Metals" a good place to seek answers to some, if not all of your questions would be:
Aluminum Casting Technology
2nd Edition
Available from: American Founfrymen's Society.
Web address: www.afsinc.org
Another site for information: www.industrialheating.com
Another site for information: www.moderncasting.com
Another site for information: www.founddrymag.com
Feel free in dropp me a note on specific's at:
drwho650@yahoo.com    ()
