DCPT and Bearing capacity
Are there any published results correlating dcp test results and bearing capacity in shallow foundations?
RE: DCPT and Bearing capacity
Might want to check out the reference below. You did not note the type of dynamic cone penetration test - so not sure if is the TRRL miniature or the Mackintosh Probe or the more robust Canadian pentest.
http://nrmt.files.wordpress.com/2010/02/513-week8....
