Callouts for material, quantity and sheet metal preferences?
Hello NX community,
I'm working on an assembly made out of several sheetmetal components. I use the master model approach to make individual drawings of these parts. I would like to have as much information as possbile "automated" in the drawing file. I wonder if and how it would be possible to show the following information in the drawing:
- Material of the referenced part
- Weight of the referenced part
- Quantity of the part in the master assembly
- K-factor (neutral factor) of the referenced sheetmetal part
- Bend radius of the referenced sheetmetal part
- Thickness of the referenced sheetmetal part
I know these last two items can also be pointed out by means of measurements, but it would be nice to be able to show this information in a table on the drawing as well.
If you know the answer to any of these questions it would be very appreciated if you can post the relevant call outs as well!
Thanks in advance!
Thanks in advance!
RE: Callouts for material, quantity and sheet metal preferences?
Are you assigning material using the Tools -> Materials -> Assign Materials.. function to assign materials?
As for the K-factor, minimum bend radius and the material thickness, these values are all recorded as Expressions in the part files created using the NX Sheet Metal module.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Yes, I have set up a parts list in my assembly drawing.
Yes, I'm using Tools>Materials>Assign materials to assign materials to the parts.
Is it possible to display these sheet metal expressions in the drawing? If so, how? Expressions are different from part attributes, right?
In each of the components create a new attribute for each of the expression you wish to see in the drawing, link the expressions to the attrubutes using Link to Expression from within the attribute dialog.
Then in your assembly drawing you can call these attributes into the parts list.
To get the expressions in the component drawings:
Create a table, exnter the expression in the table in the format <X@pxxxx> where xxx represents your expression number. You can also edit the table using a spreadsheet then under the Add-Ins tab Import NX Expressions
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
When I open the dummy part, File properties there is a listing for "Masspropmass".
When I want to add this value to the drawing template (Relationships>Object attribute) there is no listing of this value. There are values for Material and revision (DB_PART_REV) which I listed on the drawing, but not for mass. It's just not there...I'm clueless!
If you have a parts list., add a column which reports "$MASS" ( If you pick the Attribute names button in the Style dialog, you can select it there.)
If you like to type it yourself : <W$=@$MASS> in the "default text".
the component must have a weight calculated, the parts list will not calculate any .
RMB the component in the Assembly navigator- Properties - Weight - "Update Weight now" button.
You can set the update weight - thing as a default in the customer defaults such that NX recalculates on each Save.
The weight calculated will be the content of the "model" reference set. ( -if you have multiple solids in the same file.)
The density taken from the applied material OR, if this is not set the default density.
Reporting the weight of a component on a drawing without using a parts list is a lot of work. Using a pre-setup partslist along with the automatic weight calculation it can be automatic.
When it comes to assemblies it becomes more complex...
Tomas
So you're saying it's easier to get the weight from a componenent when you derive it from a partslist in an assembly drawing rather then from the component itself? This means that when there is no assembly drawing (for instance a stand-alone component) you won't be able to display the weight of a component on its drawing (whereas this information is clearly visible in the part file itself)? Does it really have to be this complicated?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Is this a new feature in NX 9? Because it doesn't happen in NX 8.5.
www.nxjournaling.com
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I've been trying to figure this out for three days now, even filed an IR three days ago. Still no working template so far...
This part file and Drawing was created using the approach that I've previously outlined. Also note that these files were created using NX 8.0 so most of you will be abel to see exactly how this works.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
IIF you have an advanced assemblies license (or other module that includes the advanced mass properties). For those of us that do not have access to the license, it will NOT update, nor will the attributes be created when we create/save a part.
If, like me, you do not have the license mentioned above; I suggest you create a body measurement in the part navigator and create your own part attribute linked to the measurement expression. As the part is modified, you will need to make sure that the body measurement stays at the bottom of the list of features, otherwise edits to the model will not be accounted for. Not as nice as John's solution, but a usable workaround...
And if you're running NX 9.0 you have an even more elegant solution to keep that extra body from interferring with downstream applications and usage. We've introduced a new 'Delete Body' function which will, for all intents and purposes, make it as if the copied body never actually existed except that the 'Measurement' feature will still update if the model is modified even if new feature are added to the model.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
In the dummy part I have created an expression called "Mass", linked to the part attribute "MassPropMass". Why do I have to create this expression manually? It would have been so much easier and self explanatory if I could have linked the note on the drawing template directly to the "MassPropMass" part attribute.
In the drawing template I created a note linked to this part attribute: <WRef1*0@Mass>
This works, but it displays the value in grams (2711 g) as 2.711000. Units are set to grams, even in the dummy part attribute list the weight is displayed correctly...any idea what could be causing this?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Tried it the other way, using a part expression...it then says <X0.0@drf_1> in the note. At least now I can control the units and the amount of digits, true! When I turn it into a template and reference a component it just keeps displaying the value of the dummy part...
Apparantly this is so complicated that even the guys at GTAC tech support can't get it to work...it's been 3 days since I filed the IR. All I want is to display the weight of the component on its drawing, I'm not asking too much now am I?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
For your reference, and for anyone else who want to have a go at it, I have attached the drawing file and the dummy part.
Just define the title block, turn it into a reference drawing template and see what happens if you use this template to make a new drawing of a component.
When I turn it into a drawing template mass just keeps on displaying the value of the dummy part. It does not update!
