UG
UG
I accidently opened a large assembly in NX7.5 and it is taking an extremely long time to open. Is there a way to interrupt the process without closing my session down with task manager?
RE: UG
<ctrl-shift>L used to work
Ben Loosli
RE: UG
is important know if you have a many folders, and if this folders is routed in the search method to open
RE: UG
Used to be very simple when running on UNIX winky smile
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
