Supplier drawing to own drawing template/part number
I have an outsource drawing that I would like to add a part number/document, or say use our own drawing template.
As I aware that if I simply "paste" or import their drawing, might not be a good idea (ethic, IP, ...)
Assume that there is no way to get a raw file from them. The only file I received is in pdf format.
What would be the approach/solution to convert or add a file name (part number)/drawing template in this received drawing?
RE: Supplier drawing to own drawing template/part number
If ASME, it would probably be best to create a Source Control Drawing which can have your own drawing number assigned to it.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
