Using the Remove Function in a Catia Product
Can anyone tell me how I can use the Remove Function in Product mode to remove a Body from a Component without it removing it from all the instances of that component? I only want to remove it from the one instance.
RE: Using the Remove Function in a Catia Product
First, we need to understand what Instance of a Part/Product is.
Instances of a Part/Product in an Assembly are referencing the relevant Part/Product file. Changes we make on an Instance are performed directly on the referenced file ie will affect all instances of the relevant Part/Product in our root assembly.
What you can do to solve your problem is:
Method No1
- Save the relevant referenced Part/Product with different name and Part Number.
- In your Root Assembly, and for the subject subject Instance replace the referenced doc with the newly created Part/Product doc.
Now you can do what you want.Method No2
Use different Representations for the subject instance.
I hope it helps.
-GEL
Impossible is nothing.
you could open a SR / PMR and see what DS says
