CATIA V5 Knowledgeware Use
I have been using Knowledgeware for a while but I need some help with a problem.
I wish to make a rule/code such that when I make a line (user enters parameter for length), I can scale (scaling option in GSD) a sketch that is at the end of the line to the other end. The problem that I'm facing is that since scaling requires a ratio parameter, everytime I change the length I need to use product optimizer which then changes the ratio parameter according to the new length of line.
I want to automate this process, any help will be appreciated.
