drawing sheet number is not in valid format
I get this message "drawing sheet number is not in valid format" when I try to insert sheet in drafting mode.
I don't get this message when I create new part file from temps. I have this problems only when I directly open a step file and save it as a part file and try to create drafting views within.
Any help will be much appreciated.
RG
RE: drawing sheet number is not in valid format
Hi Did you try to convert the step file with the dedicated "external" translator proved with your NX installation?
I Always prefer using these as the seem to be delivering a better "Cleaned" partfile.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
Hi Ron,
thanks for your quick reply. I should do that in future.
The reason why didn't to was, when I import any assembly file it loses its assembly nature. But if I directly open then I get all the structures.
May be there should some other way.
Thanks.
RG
