Need Help for PROJECT in DIGITAL SIGNAL PROCESSING
What are Linear Prediction Coefficients?Kindly notify me with the answer as it forms an important part of my project in 4th year.
RE: Need Help for PROJECT in DIGITAL SIGNAL PROCESSING
I assume that you are modelling some signals based on a set of parameters and variables.  If so then you will most likely develop a (some) linear predictive model(s).  These will be of the form G(z) = BX where:
z is a set of parameters, which are functions of the variables X; (x1, x2,....,xn) and B is a set of coefficients, which you could call linear predictor coefficients.
For the mathematical side of it might I recommend that you refer to "An Introduction to Generalized Linear Models" by Annette Dobson (Chapman and Hall, 1990)
Harry Battam
Harry.Battam@team.telstra.com
