Insulation material for piping
It is noted that the material having high density could be considered as a stronger material in regard with strength, but it is thermally weaker in the other way.Also it is not practical to achieve both parameters (Mechanically stronger and Thermally efficient) in a material.
How less density material is suppose to be called as less thermally efficient?.,Is it because of the composition?Can anyone please clarify the reason behind this?
RE: Insulation material for piping
TTFN
Vague question so vague answer.
Seriously? Consider that the worst thermal conductor is a vacuum, which has zero structural strength, and literally, zero density.
TTFN
