beam and column failure in etabs
hi everyone. I'm currently doing a structural investigation of a 20-storey building, after the analysis I found some beams to be colored red. Looking at it, It says like that the beam's shear stress due to shear and torsion exceeds maximum allowed.
my question is, does red-colored beam in etabs makes it failed already? someone told me before that as long as etabs was able to provide the required area of rebars it is ok. thanks!
RE: beam and column failure in etabs
