parenthesis on ref dimension
Hi all, I am noew to Catia I have use NX most of the time till now.
I am using V5 R21 CATIA.
Is there an easy way to put parenthesis around a reference dimentions? Or mabe a settings that by default perenthasis will be added? I am puting alot of reference dimensions and and it istime consuming (and annoying)to press so many bottons just to place parenthesis around a value. Currently I am just typing them in the 'text before' and 'text after. fields.
Yes in NX its one click and paranthesis are applied...
Thank you.
Thank you.
RE: parenthesis on ref dimension
Alternatively, multi-select the target dimensions, go to the properties window and add them under the Dimension Texts tab.
You can add the macro to a toolbar, then it would be one-click operation.
I have used it on V5R18 many times , haven't tried it on V5R21. (I assume that it will work on 21).
You can multi select dimensions that are even in different views, run the macro and you should have () on them all.
Copy and paste the following to a macro catscript:
Sub CATMain()
Dim MySel As Selection
Set MySel = CATIA.ActiveDocument.Selection
Dim MyDim As DrawingDimension
Dim Array1 As String
Dim Array2 As String
Dim Array3 As String
Dim Array4 As String
For i = 1 To MySel.Count
If TypeName(MySel.Item(i).Value) = "DrawingDimension" Then
Set MyDim = MySel.Item(i).Value
MyDim.GetValue.GetBaultText 1,Array1,Array2,Array3,Array4
MyDim.GetValue.SetBaultText 1, "(", ")",Array3,Array4
End If
Next
End Sub
Check here
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
