Visual notice of errors to geometric constraints
Example: I have two bodies in a part file, the top plate has a countersunk hole, the bottom plate has threaded holes constrained to the countersunk holes. During the design change the top plate holes are switched to counter bore holes and the counter bore holes are moved slightly. I did not consider the hole change would break the constraint between the two sets of holes, but they did and the threaded holes remained in the original location. It would be nice to have a flag pop up (like the feature info alert) in the part navigator letting the user know there is a possible problem in the sketch/feature to review.
Is there a setting to turn on a visual notice, such as informational flag in the Part Navigator that sketch constraints have been broken?
NX 8.5.3.3
NX 8.5.3.3
RE: Visual notice of errors to geometric constraints
www.nxjournaling.com
NX 8.5.3.3
Does that mean there is no ability to flag/identify problematic geometric constraints outside of the feature?
NX 8.5.3.3
