Bolt Torque
Bolt Torque
Bolt Torque
I understand that Purpose of tightening the screws/Bolts are to fix Axial tension of the Object.
However, I need a better explanation which allow me to know about it in Depth and how to find out Bolt torque as well.
Can anyone assist me in this regard?
RE: Bolt Torque
look into the FAQs ... there are many threads on bolt torques
Quando Omni Flunkus Moritati
RE: Bolt Torque
Hi All,
Thanks for the interest shown on this query.,
Let me try the link, It seems to be vague.,
RE: Bolt Torque
Assuming you are referring to "structural / heavy industry" applications (cf. say aerospace etc) this is one of the better publicly available resources that I have found:
http://www.cisc-icca.ca/files/publications/techpub...
Subject to the earlier assumption, you will find the torque of the fastener is generally not a criterion of consideration.
I propose although this is a good start, it is not exhaustive (and may not reflect your local requirements etc) and hence you should consult your relevant local resources etc as required.
Lyle
RE: Bolt Torque
Do you "know" the (axial) forces your bolted joint will be subjected to?
Have you looked into possibilities of bolted "flange" features creating a prying action in addition to simple tension?
RE: Bolt Torque
Hi All,
Thanks for your response, I am just looking for an understanding and not into any technical applications.
RE: Bolt Torque
Sundarzplanet,
Take a look at either Lamon's or Flexitallic's Bolted Joint/Gasket Handbooks. They are full of good information about bolt loadings.
Rick
RE: Bolt Torque
You may also want to look into ASME PCC-1, which provides torque and fit-up suggestions.
RE: Bolt Torque
Thanks ricklts & qualeng1 for your suggestions, I will try.,
