Create a Drawing Stepped Section View using NXOpen ?
Hello Everyone,
Can someone help me out with some sample code snippet on how we can go about creating a stepped section view using NXOpen ?
I tried searching for some sample code which can get me started in the Siemens GTAC forum but to no avail.
Also the Journal recorder is not working while creating a drawing section view.
Any help in this regard will be deeply appreciated.
Thanks & Regards,
Amitabh
RE: Create a Drawing Stepped Section View using NXOpen ?
Friends,
When I am trying to use this code which I created by having a look at the NX Help File.I am getting an NXException saying "Not Implemented" in the line "objSectionViewBuilder = objPart.DraftingViews.CreateSectionViewBuilder(objSectionView)"
Does that mean this API is not exposed to automation ?
CODE --> vb
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Drawings
Imports NXOpen.UF
Imports NXOpen.UI
Module CreateSectionView
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = theSession.Parts.Display
        Dim objParentView As DraftingView = Nothing
        Dim objStartPoint As Point3d = Nothing
        Dim objEndPoint As Point3d = Nothing
        Dim objSectionViewLoc As Point3d = Nothing
        If select_a_drawing_member_view(objParentView, "Select a parent view for the detail view") = Selection.Response.Ok Then
            'Select the boundary point of the detail view circle
            If select_screen_pos(objStartPoint, sPrompt:="Select a Start hinge point for the section view") = Selection.Response.Ok Then
                If select_screen_pos(objEndPoint, sPrompt:="Select a End hinge point for the section view") = Selection.Response.Ok Then
                    'Select the location to place the detail view
                    If select_screen_pos(objSectionViewLoc, sPrompt:="Select a point to place the detail view") = Selection.Response.Ok Then
                        'Create the section View
                        FnCreateSectionView(workPart, objParentView, objStartPoint.X, objStartPoint.Y, objEndPoint.X, objEndPoint.Y, _
                                            objSectionViewLoc.X, objSectionViewLoc.Y)
                    End If
                End If
            End If
        End If
    End Sub
    Public Function FnCreateSectionView(ByVal objPart As Part, ByVal objParentView As DraftingView, _
                                        ByVal dXStartPoint As Double, ByVal dYStartPoint As Double, _
                                       ByVal dXEndPoint As Double, ByVal dYEndPoint As Double, _
                                       ByVal dPosSectionVwX As Double, ByVal dPosSectionVwY As Double) As SectionView
        Dim objSectionView As SectionView = Nothing
        Dim objSectionViewBuilder As SectionViewBuilder = Nothing
        Dim objSvt As SvtBuilder = Nothing
        Dim objHingeLineBuilder As HingeLineBuilder = Nothing
        'Hinge Line Direction
        Dim dir As Direction = Nothing
        Dim objStartPoint As Point = Nothing
        Dim objEndPoint As Point = Nothing
        Dim objSectionViewCreated As SectionView = Nothing
        Dim unit1 As Unit = CType(objPart.UnitCollection.FindObject("MilliMeter"), Unit)
        'If a null reference (Nothing in Visual Basic), then creates a section view
        Try
        'Section view tool builder
        objSvt = objSectionViewBuilder.SectionViewTool
        'Default Properties
        objSvt.Orientation = False
        objSectionViewBuilder.ViewPlacement.AlignmentMethod = ViewPlacementBuilder.Method.Infer
        objSectionViewBuilder.ViewPlacement.AlignmentOption = ViewPlacementBuilder.Option.ToView
        'Parent View
        objSectionViewBuilder.ViewPlacement.AlignmentView.Value = objParentView
        objSectionViewBuilder.ViewStyle.ViewStyleGeneral.AngleValue = 0.0
        objSectionViewBuilder.ViewStyle.ViewStyleGeneral.Scale.Denominator = 1.0
        objSectionViewBuilder.ViewStyle.ViewStyleGeneral.Scale.Numerator = 1.0
        objSectionViewBuilder.ViewStyle.ViewStyleGeneral.Scale.ScaleType = ViewScaleBuilder.Type.Ratio
        objSectionViewBuilder.ViewStyle.ViewStyleOrientation.HingeLine.ReverseDirection = False
        objSectionViewBuilder.ViewStyle.ViewStyleOrientation.HingeLine.VectorOption = HingeLineBuilder.Hingeline.Defined
        Dim expression5 As Expression
        expression5 = objPart.Expressions.CreateSystemExpressionWithUnits(dXStartPoint.ToString, unit1)
        Dim scalar1 As Scalar
        scalar1 = objPart.Scalars.CreateScalarExpression(expression5, Scalar.DimensionalityType.None, SmartObject.UpdateOption.AfterModeling)
        Dim expression6 As Expression
        expression6 = objPart.Expressions.CreateSystemExpressionWithUnits(dYStartPoint.ToString, unit1)
        Dim scalar2 As Scalar
        scalar2 = objPart.Scalars.CreateScalarExpression(expression6, Scalar.DimensionalityType.None, SmartObject.UpdateOption.AfterModeling)
        Dim expression7 As Expression
        expression7 = objPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
        Dim scalar3 As Scalar
        scalar3 = objPart.Scalars.CreateScalarExpression(expression7, Scalar.DimensionalityType.None, SmartObject.UpdateOption.AfterModeling)
        objStartPoint = objPart.Points.CreatePoint(scalar1, scalar2, scalar3, SmartObject.UpdateOption.AfterModeling)
        Dim expression8 As Expression
        expression8 = objPart.Expressions.CreateSystemExpressionWithUnits(dXEndPoint.ToString, unit1)
        Dim scalar10 As Scalar
        scalar10 = objPart.Scalars.CreateScalarExpression(expression8, Scalar.DimensionalityType.None, SmartObject.UpdateOption.AfterModeling)
        Dim expression9 As Expression
        expression9 = objPart.Expressions.CreateSystemExpressionWithUnits(dYEndPoint.ToString, unit1)
        Dim scalar11 As Scalar
        scalar11 = objPart.Scalars.CreateScalarExpression(expression9, Scalar.DimensionalityType.None, SmartObject.UpdateOption.AfterModeling)
        Dim expression10 As Expression
        expression10 = objPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
        Dim scalar12 As Scalar
        scalar12 = objPart.Scalars.CreateScalarExpression(expression10, Scalar.DimensionalityType.None, SmartObject.UpdateOption.AfterModeling)
        objEndPoint = objPart.Points.CreatePoint(scalar10, scalar11, scalar12, SmartObject.UpdateOption.AfterModeling)
        dir = objPart.Directions.CreateDirection(objStartPoint, objEndPoint, SmartObject.UpdateOption.AfterModeling)
        objSectionViewBuilder.ViewStyle.ViewStyleOrientation.HingeLine.SpecifyVector = dir
        objSectionViewBuilder.ViewStyle.ViewStyleOrientation.Ovt.AssociativeOrientation = False
        objSectionViewBuilder.ViewUnfolded = True
        'Place the Section View
        Dim ObjSectVwPlacementPoint As Point3d = New Point3d(dPosSectionVwX, dPosSectionVwY, 0.0)
        objSectionViewBuilder.ViewPlacement.Placement.SetValue(Nothing, objPart.Views.WorkView, ObjSectVwPlacementPoint)
        Dim nXObject1 As NXObject
            If objSectionViewBuilder.Validate Then
                nXObject1 = objSectionViewBuilder.Commit()
                objSectionViewCreated = CType(nXObject1, SectionView)
                FnCreateSectionView = objSectionViewCreated
            Else
                FnCreateSectionView = Nothing
            End If
            objSectionViewBuilder.Destroy()
        Catch ex As NXException
            Dim lw As ListingWindow = Session.GetSession.ListingWindow
            lw.Open()
            lw.WriteLine(ex.Message)
            lw.WriteLine(ex.StackTrace)
        End Try
    End Function
    Function select_a_drawing_member_view(ByRef dwgview As Drawings.DraftingView, ByVal sPrompt As String)
        Dim ui As UI = GetUI()
        Dim mask(0) As Selection.MaskTriple
        With mask(0)
            .Type = UFConstants.UF_view_type
            .Subtype = UFConstants.UF_all_subtype
            .SolidBodySubtype = 0
        End With
        Dim cursor As Point3d = Nothing
        Dim vw As TaggedObject = Nothing
        Dim resp As Selection.Response = _
        ui.SelectionManager.SelectTaggedObject(sPrompt, _
            sPrompt, _
            Selection.SelectionScope.AnyInAssembly, _
            Selection.SelectionAction.ClearAndEnableSpecific, _
            False, False, mask, vw, cursor)
        If resp = Selection.Response.ObjectSelected Or _
           resp = Selection.Response.ObjectSelectedByName Then
            dwgview = CType(vw, Drawings.DraftingView)
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Function select_screen_pos(ByRef loc As Point3d, Optional ByVal sPrompt As String = "Screen Position:") As Selection.Response
        Dim resp As Selection.DialogResponse = Selection.DialogResponse.None
        Dim localView As View = Nothing
        UFSession.GetUFSession.Ui.SetCursorView(1)
        resp = UI.GetUI.SelectionManager.SelectScreenPosition(sPrompt, _
                                                             localView, loc)
        If resp <> Selection.DialogResponse.Back And _
           resp <> Selection.DialogResponse.Cancel Then
        Else
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
Amitabh
