A fourth of a shape is a quadrant... What is a third?
I have a machine that is divided into thirds, and was going to use the equivalent of "quadrant" in the part description, but can't find one...
Any ideas or suggestions?
David
Check out my professional profile and connect with me on LinkedIn. http://lnkd.in/fY7-QK
RE: A fourth of a shape is a quadrant... What is a third?
"a machine" ?
quadrants would be a bad choice (to describe 4 pieces)
i'd suggest "the machine is comprised of three sub-assemblies (or components)" possibly add "called/described as ... Huwey, Dewey and Luwey" giving them descriptive names; else "the first comprises of ...; the second ...; and the third ..."
Quando Omni Flunkus Moritati
A tertiant.
IMHO that's a bit of a stretch, and not easily understood
It's not a machine. It's atird of a machine.
It would be better to have a distinct name for each part and go with that. That way you could refer to a part or assembly "X" in your correspondence and design drawings - similar to what we do in shop drawings.
Mike McCann
MMC Engineering
each one might be a skid
" It's atird of a machine." Now that is being somewhat judgmental. :)
The best term, I think, would be "section". Even if your machine had four sections, I don't think that quadrant would be the appropriate term, as it would mean sector rather than section.
A "quadrant" is not just "one-fourth" part of something; it is very specifically one-quarter of a full circle.
Unless your machine is in the form of a full circle, and is cut up radially like pieces of pie, then "quadrant" is not the right term. If it is in fact cut up into four equal pieces, then quadrant is correct; if it is cut up into three equal 120-degree sectors, then I would call them "120-degree sectors".
http://julianh72.blogspot.com
==> A "quadrant" is not just "one-fourth" part of something; it is very specifically one-quarter of a full circle.
That depends entirely on context. While one-quarter of a full circle is a quadrant, not all quadrants are one-quarter of a full circle, i.e., one quadrant of a Cartesian grid.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Tertiant is correct but very few readers will understand.
I would agree with section. "Unit" may also be used. Take an injection molding machine for example. One has the clamp section and the injection section. You might be better off adding a descriptor to the word "section" to be the most technically and functionally accurate in manuals, instruction, and labeling.
if you're talking about "a machine", a complicated device that breaks down into three majot components, give the components names.
The top of this machine is divided into 3 equal and identical sections... Was wanting something simple and descriptive for the drawing titleblock, so it needs to be somewhat short.
I just ended up calling it a "top table section".
David
I've divided a 'drawing' into quadrants (using cartesian axes) but never a device or component. Did this to make it easier for field service and quality to identify where failures were occuring
don't your drawings have zones on the border, A-H and 1-9, so you can point to a specific part of the drawing, like E4 ?
My machine is divided into quadrants = My machine is divided into fourths.
My machine is divided into tertiants = My machine is divided into thirds.
I'd use "thirds."
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
"It's atird of a machine."
Being as this is the "Language and Grammar" forum...
That should be spelled "A TURD"
And, being as it's not built yet, I can't determine if it is a turd or not. Hopefully not.
David
Sounds the same, but I do not type profanity in this forum. At least I don't think I do... censored
Mike McCann
MMC Engineering
I'd call it a Thirdand/Thirdrant or Tridant (not the gum but that'd make a good joke)
5,6,7,8 = Pentant, Hexant, Septant, Octant
Sectors A, B, C would sound cool.
My last thought is You could say
FrontRight, Back & LeftRight
Front, Right_Back & Back_Right like the IsoMetric views did.
"TrIsometric" "Tetrant"
http://www.mathsisfun.com/platonic_solids.html
PS: What if we had chosen to use the duodecimal number system.
DuoDecimal&Dozenalism
bull|
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
I have a pack of Trident right here on my desk... Spelled differently than Tridant... Useful after those Friday liquid lunches.
David
tercile
Trident: Quadrant:: triple:quadruple. Depends on what object you're choosing to apply any of these on.
I was going to suggest Table Top Section, but I see that I'm a bit late to the party.
Jeff Mirisola, CSWE
My Blog
"Tertian" or "tierce" has its origin the Latin word tertianus meaning 1/3 rd.
If the machine is circular, I agree with SECTOR.
If the machine isn't circular at all, then try SEGMENT.
Are the individual parts are shaped like ARCS or WEDGES?
Hopefully not too far off topic: Did anyone out there ever celebrate their 33-1/3 anniversary, or 66-2/3 birthday?
It's a great way to surprise people, and a great excuse for a party for people who are numerically minded enough to get it.
STF
