Difference between Boiler Valve & Furnace Valves
What is the difference between Boiler valves & Furnace Valves. We are using ASME Section1 Valves in Our Boiler & Furance(steam application)
RE: Difference between Boiler Valve & Furnace Valves
nasim123,
First of all the valves must to follow the same code of the equipment that they protect. Boilers, superheaters and fired vessel are case where ASME I are applied.
There is no difference from one each other. In other words, both valves must to follow ASME I requirements since the pressure operation exceds 15 psig.
