normalizing after forging
Dear Friends
required ur expect advice, we are OEM manufacturers of axle shafts and earlier we used to follow the same pattern of oem towards our domestic customers, but due to price appreciation and like many other bigs vendors we have to skip one process of Normalizing to save a substantial cost.many big oem vendors are not following normalizing aqfter forging of rear axle shafts for after market sale....my point is
1.is it necessary to do normalizing like we use 1541H steel
2.is there any alternate to normalizing?
3.what will be the effect on durability n strength of rear axle shaft if we skip normalizing....
rgds
rgds
RE: normalizing after forging
I have been in working for 4 decades and have only seen a few instances where normalizing was absolutely needed. Usually, cases where consistency of the heat treatment is paramount, such as for sour service steels above 100 KSI SMYS, or cases where (IMO) unnecessarily high Charpy Impact values were specified. I've seen a lot more cases where it (or a second Q&T operation) helped.
There are some issues that occur when the steel is exposed to forging temperatures and has an unpredictable cooling rate, most common is carbon segregation. This is worse with the high manganese steels. With the slow cooling that can occur coming off the forge, you can develop significant banding which can cause problems with your HT response.
One approach I have seen with some success is pseudo-normalizing. That is, austenitize the parts at 1750-1775F (Make sure you have an an aluminum-killed steel, preferably with Cb and or V). The higher austenitizing temperatures are needed as the lean bands are essentially ferrite, which won't austenitize unless you get it above 1670F. Yeah, some say 1750 is high, and it is, but you really have to hit a heavily banded structure hard to get it to transform. After you have a good soak at 1750F, let it cool to 1550 before oil quench. Quenching from 1750 is not advised; this is asking the oil to do more than it has to (remove more heat), which is not your goal. This will take a little more furnace time than a normal Q&T, but it will knock out a lot of the problems that arise when the normalizing operation is skipped.
Mind you, this does not produce the finest GS you could get, but in many cases, it will produce acceptable results.
rp
1541H is hot forged at temperatures between 2200 and 1600 degF. The reason for normalizing after hot forging is to provide a controlled and uniform metallurgy in the forging at the start of machining operations. The conventional hot forging process does not allow for controlled cooling of the part. The 1541H blank/preform is simply heated to the required temperature (1600 to 2200 degF), subjected to the forging operation, if necessary reheated and subjected to further forging operations, and finally set aside to air cool.
The typical recommended processing for hot forged 1541H is normalize at 1650degF and air cool, anneal at 1525degF and furnace cool to 1200degF at a rate of 50degF/hr or less, then rough machine. If you want to skip the post-forge normalize operation to save cost, then I'd assume you will skip the post-forge anneal step also, right? Just be aware that by skipping these heat treat operations your finished 1541H component will have lower quality. I've attached some information showing the effect on 1541H metallurgy due to various heat treat conditions.
There are some steel alloys similar to 1541H available that are designed for direct quenching immediately after hot forging. So you might look into using one of them if processing cost is your concern.
Hope that helps.
Terry
Perhaps, this must have motivated the jackal3's company to suggest avoid normalising for after market parts.I agree with the previous posts of the benefits of normalising a forging.
The material and processing OEMs use for a given component are usually highly optimized for a specific application. If you use the same material for a component, but skip some of the processing steps to save cost, you should not expect to get equivalent performance from the finished component. As others noted, skipping the normalizing step can result in inferior microstructure in the finished component. And this can affect fatigue life of the shaft. Lower overall statistical fatigue life in your aftermarket shaft product can result in higher warranty replacement costs. It would be interesting to see the results of a trade study comparing the cost savings of skipping the normalizing step versus any impact from higher warranty replacement costs due to reduced service life of the shafts.
You are correct, the OEM parts are more cost sensitive and there are more efforts used for cost optimization. Sometimes aftermarket parts are made to lower requirements to increase margin for profitability, especially if the expected lifetime is lower (e.g. only a fraction of the entire vehicle's life).
Cory
