Motorcycle clutch lever pressure reduction
Is there a way to modify a clutch lever handle on a 1987 Harley Davidson FXR for less pull pressure? Possibly change the fulcrum point? I already have the factory 40% clutch reduction kit and the weakest clutch diaphram spring and a brand new clutch cable installed. These things helped but not enough.
RE: Motorcycle clutch lever pressure reduction
http://www.harley-davidson.com/store/se-variable-p...
should help with your problem, if used with a lower force clutch spring.
Unfortunately the site does not make it clear if the part fits your bike. Selecting the button for fit check appears to bring up a list of every model made for each year selected.
Unfortunately the lone 'review' was written by an idiot.
Unfortunately 'technical detail mentions two clutch springs that are stiffer than stock, meaning the copy writer does not understand the purpose of the offered part.
H-D should be embarrassed by the site.
Back to your lever problem:
Post a photo from which we can gauge the lever's proportions, and maybe someone can help.
Mike Halloran
Pembroke Pines, FL, USA
The cable end rotates with the lever just as the lever rotates relative to the bar. If a drop of gun oil on each of those rotating joints improves the handle force temporarily, then better bearings might improve it longer term. There's probably a way to squeeze a needle bearing into the handle pivot, at least.
Mike Halloran
<tangent>
A long time ago, I though about becoming a writer. I figured that someone like Dave Barry had to write about a million words a year to make a living at it. I figured I'd get Carpal Tunnel Syndrome from typing that much, and decided not to do it.
By an odd stroke of fate, I later got into programming microcomputers, and did it pretty heavily for ten years. ... at way more than a million words a year. I got CPS, big time.
Then I got t-boned in a car, and the airbags messed up my wrists even more, and wearing wrist splints for a couple of months made it difficult to move my fingers at all.
As part of the physical therapy for that, I bought a hot wax bucket and dipped my hands and wrists in melted paraffin regularly for a few weeks. Any mild heat source would do, but the paraffin ensures intimate contact and carries enough heat to do some good until it cools enough to peel it off.
Since then, I've been taking daily doses of glucosamine and chondroitin. Generics seem to work as well as the heavily advertised name brands. If I miss a couple days, my hands start to stiffen up.
</tangent>
Talk to your doctor about your wrist.
Mike Halloran
http://www.jpcycles.com/product/500-409
Search the jp cycles site for 'power clutch', and at least two different "AMP Research Power Clutch" will come up. I couldn't figure out which fits your bike. Give them a call.
Mike Halloran
Along your lines of the heated paraffin, I got pretty good results using capsaicin (pepper) rub. One major down side is you have to be very careful not to touch your eyes (or other sensitive areas). Then I found out about Vitamin D. It has a profound effect on arthritis and joint problems. Now I take 5000 IU daily and my hands are better than they have been in years. I do take glucosamine and chondroitin too but for me they only seem to slow deterioration, not give any relief to existing symptoms.
Mike Halloran
