software
software
which software would one use to investigate the cause of pipe burst?
RE: software
RE: software
How large pipe and do you know/suspect why it failed? Pipe burst... from pressure? from freezing? or what? Failure because it was restrained? Corrosion issues? Inferior pipe (we had some Chinese 10" stuff that should have tested to 1000+ psi... it failed at a little over 100 psi; test values and coupons were identical except for the ID number) We use Caesar II for pipe design but mostly for forces/restraints.
Dik
RE: software
RE: software
I hate Windowz 8!!!!
RE: software
RE: software
RE: software
