Postprocess for 5 axis
Hi, this is my first post, my name is chuy,
I need your help, because I need add to my actual post process in 3 axis, add 4 and 5 axis only in position, I like know how I can add this mores 2 axis in my post, because I no´t like starting again from zero in my post.
I used NX9
If everybody can help me I appreciated your help
RE: Postprocess for 5 axis
Create a new 5 axis post and on the create new postprocessor dialog set the controller to User's and browse to select your existing 3 axis post. Now you have a 5 axis post with the same controller as your existing post.
Hi Joycejo,
Thanks a lot for your wonderfull tip, i happy
