what is the equation for the number of wire turns in a system consists of two co-axial transformer
I have a coaxial transformer coils in order to transfer the power in a wireless manner. I would like to know for a certain power, voltage and frequency how many turns of wire each coil needs. Assume the followings:
Power= 1 W
Voltage= 5 V
Frequency= 300 KHz
Number for turns=???
Also, I have attached the dimensions for the coils. There is a 0.02" air gap between two coils.
Power= 1 W
Voltage= 5 V
Frequency= 300 KHz
RE: what is the equation for the number of wire turns in a system consists of two co-axial transformer
I'm a little fuzzy on how you intend to wind the coils, particularly the outer one. ... but since you have shown zero coil detail, maybe I am misinterpreting what you failed to include in your drawing.
Mike Halloran
Pembroke Pines, FL, USA
IIRC, the old rule of thumb was to aim for enough inductance to provide an input Z under open circuit secondary conditions of at least ten times the normal operating load.
Disclaimer - this from memory, so double check.
