60079-11 Ferrite Bead Inductance Calculation
I have a design which needs to meet IEC 60079-11 instrinsic safety. Does anyone have experience calculating the inductance of ferrite beads specifically for IS? I have been told that the inductance needs to be calculated at 1KHz for IS, however, the datasheet for the ferrite bead we are using has information down to 1MHz only. How can I show quantitatively what the inductance is at 1KHz, or how should I go about including beads in the inductance calculations?
RE: 60079-11 Ferrite Bead Inductance Calculation
