Run Macro in Assembly to remove the properties to all components
i have the below Macro in order to open each parts of the active assembly, what i need is after they open, delete all the Properties (also the custom) except the Description
They just open all the parts of the assembly or delete the properties, but don't works at the same time for all the parts, some body can give me a tips to fixed?
Dim swDoc As SldWorks.ModelDoc2
Dim swAllDocs As EnumDocuments2
Dim FirstDoc As SldWorks.ModelDoc2
Dim dummy As Boolean
Dim NumDocsReturned As Long
Dim DocCount As Long
Dim i As Long
Dim sMsg As String
Dim swApp As SldWorks.SldWorks
Dim bDocWasVisible As Boolean
Dim OpenWarnings As Long
Dim OpenErrors As Long
Dim DwgPath As String
Dim myDwgDoc As SldWorks.ModelDoc2
Sub ShowAllOpenFiles()
Set swApp = Application.SldWorks
Set swAllDocs = swApp.EnumDocuments2
Set FirstDoc = swApp.ActiveDoc
DocCount = 0
swAllDocs.Reset
swAllDocs.Next 1, swDoc, NumDocsReturned
While NumDocsReturned <> 0
bDocWasVisible = swDoc.Visible
swApp.ActivateDoc swDoc.GetPathName
DwgPath = swDoc.GetPathName
If (LCase(Right(DwgPath, 3)) <> "drw") And (DwgPath <> "") Then
DwgPath = Left(DwgPath, Len(DwgPath) - 3) & "drw"
Set myDwgDoc = swApp.OpenDoc6(DwgPath, swDocDRAWING, swOpenDocOptions_Silent, "", OpenErrors, OpenWarnings)
If Not myDwgDoc Is Nothing Then swApp.ActivateDoc myDwgDoc.GetPathName
Set myDwgDoc = Nothing
End If
'End If
DocCount = DocCount + 1
Wend
swApp.ActivateDoc FirstDoc.GetPathName
End Sub
Sub main()
Dim swModel As SldWorks.ModelDoc2
Dim retval As String
Dim Desc As String
Dim retvals As String
Set swModel = swApp.ActiveDoc
Desc = swModel.GetCustomInfoCount
retval = swModel.DeleteCustomInfo("Number")
retval = swModel.DeleteCustomInfo("DrawnBy")
retval = swModel.DeleteCustomInfo("CheckedBy")
retval = swModel.DeleteCustomInfo("Engineered By")
retval = swModel.DeleteCustomInfo("EngAppDate")
retval = swModel.DeleteCustomInfo("Project#")
retval = swModel.DeleteCustomInfo("DrawnDate")
retval = swModel.DeleteCustomInfo("CheckedDate")
retval = swModel.DeleteCustomInfo("Out source Co.")
retval = swModel.DeleteCustomInfo("OutSourceDate")
retval = swModel.DeleteCustomInfo("Revision")
retval = swModel.DeleteCustomInfo("Designer")
retval = swModel.DeleteCustomInfo("Detailer")
retval = swModel.DeleteCustomInfo("DesignDate")
retval = swModel.DeleteCustomInfo("Released Date")
retval = swModel.DeleteCustomInfo("State")
retval = swModel.DeleteCustomInfo("Purchased")
retval = swModel.DeleteCustomInfo("TABULATION BALLOON")
retval = swModel.DeleteCustomInfo("SWFormatSize")
retval = swModel.DeleteCustomInfo("Machine")
retval = swModel.DeleteCustomInfo("Designer By")
retval = swModel.DeleteCustomInfo("Weight")
retval = swModel.DeleteCustomInfo("OriginationDate")
retval = swModel.DeleteCustomInfo("Component Type")
retval = swModel.DeleteCustomInfo("Manufacturer")
retval = swModel.DeleteCustomInfo("Manufacturer Number")
retval = swModel.AddCustomInfo3("", "Description", swCustomInfoText, Desc)
'retval = swModel.DeleteConfiguration("Desc")
'retval = swModel.AddCustomInfo3("", "Number", swCustomInfoText, "T50000")
'retval = swModel.DeleteCustomInfo("COMPANY")
'retval = swModel.AddCustomInfo3("", "COMPANY", swCustomInfoText, "VENTURADS.COM")
End Sub
Dim i As Long
Dim sMsg As String
DocCount = 0
swAllDocs.Reset
End If
'End If
Wend
End Sub
Sub main()
Dim Desc As String
End Sub
RE: Run Macro in Assembly to remove the properties to all components
SolidWorks macro always start with Main procedure. You have written Main procedure to delete custom properties alone. The 'ShowAllOpenFiles' procedure only opens all the part files and drawing files. You have to change 'ShowAllOpenFiles' as Main and main as another one. Another problem is that You are no where calling second sub procedure in your coding.
I have altered your code slightly. Just check it.
Dim i As Long
Dim sMsg As String
Sub main() 'ShowAllOpenFiles()
DocCount = 0
swAllDocs.Reset
DeleteProperties
End If
'End If
Wend
End Sub
Sub DeleteProperties()
'Dim swApp As SldWorks.SldWorks
Dim Desc As String
'Set swApp = Application.SldWorks
End Sub
V K Amirtharaj
EGS Computers India Pvt Ltd
Dassault System SolidWorks Reseller
Chennai | Tamilnadu | India
http://www.egsindia.com/solidworks.html
http://www.egs.co.in
