MOC,GASKETS FOR HIGH TEMPERATURE PRESSURE APPLICATIONS
Please... Need help in the design of a valve for High temperature pressure applications i.e.
of the order of 1300 degrees 150 bar.
All suggestions are welcome . Please respond
RE: MOC,GASKETS FOR HIGH TEMPERATURE PRESSURE APPLICATIONS
What is this valve going to be designed to do?
it can be either on/off or flow control.
any suggestions?
the conditions are high temperature gas applications.
I think my data is right.
I have to agree with micalbrch here....I have a large problem visualizing the the application.
The only thing that comes to mind is a solution with ceramic materials either complete, or as lining. If other (metallic) materials are to be used in addition, either sufficient cooling or insulation, or both, must be envisaged. Sizes are not mentioned here, but ceramic valves does exist for lower temperatures. This high? A needle-valve construction with a 90 degree-bend and the needle operated from the outside of the bend?
