Production release revision blocks
Hi All
At production release, each drawing rev block is updated with rev, "release to production" and dated.Unfortunately it is a manual process. has anyone a macro, batch processing similar to task scheduler that would automate this update of the revison block?
RE: Production release revision blocks
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
ctopher - so if you have a hundred drawing to rev before a production release, you have to open each one and paste from notepad?
But, I only do a couple drawing here and there every day. I don't have 100 drawings that would require some type of macro to do it.
Only takes seconds to type the required info on each drawing.
Chris, CSWA
SolidWorks 14
ctopher's home
SolidWorks Legion
