Napping to points with lines/arcs/ circles to geometry in a drawing sheet
I am having an issue with NX7.5. I create a solid model then add it to a file I have of a drawing sheet template (inserting the component in modeling), then I add my views. In doing so I have no ability to snap lines to centers or endpoints of the part. I can get centerlines to snap to points on the view but basic lines do not.
Any ideas?
I found that if I go to drafting from the original solid model it works but if I "Add the component" to a drawing sheet I have saved (Open the drawing sheet file -> add component in modeling -> insert views in drafting) I can't snap to centerpoints/endpoints/etc.
The snap options are active so I know that is not the issue.
Thanks!
Any ideas?
Thanks!
RE: Napping to points with lines/arcs/ circles to geometry in a drawing sheet
Yes, I know it was a simple typo, but I couldn't resist
