Flat Plate Simply Supported at Each Corner With Central Point Load
Hi All
I have a problem which is causing a bit of an issue. I have a rectangular flat plate that has a central point load and is simply supported at each of its four corners. I am trying to find a standard case in literature from which I can perform the stress analysis which conforms to this condition. As yet I have not been able to find anything. if anyone knows where I might find a standard condition that fits this please could you let me know.
Thank you very much.
RE: Flat Plate Simply Supported at Each Corner With Central Point Load
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
TTFN
http://www.xcalcs.com/cgi-bin/tutti/x3calcs.cgi?d=...
TTFN
