How to turn on Dynamic Viewing?
It's a simple question but I haven't found the way to turn ON the Dynamic Viewing un the Post Processing Module.
For some mysterious reason I have turn it off, but I don't remember the steps to turn it on.
thanks for your help,
Jalarron
Jalarron
RE: How to turn on Dynamic Viewing?
just check out the possible solution.
u can make dynamic viewing on by F6 key. keep holding F6 key pressed, move the mouse up and down. u will get the required pan, zoom and rotate options in the process. u can observe the changing icons above the prompt window and release the F6 key when u get the required icons.
good luck.
