Exporting MPEG Problem
Hi everyone,
I am trying to create an assembly Video. Since the sequence tool was too limited in its options, I decided to use the motion simulation tool. I have been using a gearbox to tinker and experiment on, but if I use the Export to Movie funktion, the video qualaty is simply horrible. I read in other forum posts that one can use export > MPEG, but that has been stuck on generating Image-Based Lighting over and over again and once it gets to frame 4 or 5, it sometimes randomly skips BACK a few frames to regenerate Image-Based Lighting. I tried to reduce the number of frames, but I can't even get it to finish a working 3 frame video...
The thing is, I'd be happy to have an export of the Preview Animation it offers to show me. Which it can generate in real-time without any problems. So if anyone knows where I can edit the visual properties of the export, I'd be so happy!
oh, before anyone suggests this: I have considered a screen capture tool. But that's not the point. I want to get the NX export to work.
RE: Exporting MPEG Problem
That being said, the issue of the NX code continuously going back and forth a few frames at a time while generating an MPEG movie, that's normal behavior since MPEG is a compression standard and so it has to generate a few frames before it knows how much data (pixels) it can merge together as it compresses the data from one frame to the next. Yea, it looks weird as you watch it process, but that's just the way it has always worked, whether you're using 'Image-Based lighting' or not.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Is the assembly very large ? Rendering images is very heavy on RAM, watch the Task manager such that you don't run out of RAM while rendering.
Exporting a Mpeg takes a long time, mpegs run default at 24 frames per second which means NX must render 24 images per second of movie. NX might not have crashed , it's simply in the middle of the rendering process.
As John notes, the rendering works that way that it jumps back and forth in the simulation and then compresses the images/frames in between. If one grabs a copy of the Mpeg file before it is finished , it will display that jumping effect.
Can you setup the Image based lighting such that you get a good/ decent image in a static rendering ? - If not, the video will not be better.
Have you read my reply in this thread on where to set the mpeg options ? :
http://www.eng-tips.com/viewthread.cfm?qid=362940
What is wrong with the visual properties of the real time export ? - What do you want to edit ?
Tomas
I had not seen that thread before, but there was no option there to disable the Image Based-Lighting and any other changes there did not seem to effect the process much.
As to what I don't like about the real time export is, that it is NOT what I see on my screen but a worse quality. It even has a few display errors in it, like ghosts of lines that have already moved away.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I did not notice the ghost lines until i read your note about it and then looked extra cautiously.
The slowness is probably due to the 300 frames in total, if you want a 30 second video, try 30[seconds]*24[frames per second] = 720 Frames ( or more to have a smoother movement in the video.) - then it is up to the graphics adapter if it can deliver this or not when doing the real time export.
If you would like to turn off the Image based lighting, you need to do so in the render setup. ( what version of NX ?)
Pre NX 9 it is : View- Visualization - Basic Scene Editor - Image based Lighting - Use...
+ set other rendering options for the video.
Tomas
I have tinkered a bit with the settings and now am getting a Picture quality that I am contend to work with but the Export to Movie funktion exports with 4 or 5 frames per Second, which is just not enough. I would like to have 30, or at least 24 FPS, but where in the options can I change this?
I doubt , but don't know, that we can change the real time export.
Tomas
I have still struggled with this for days because no one really explained how to set the resolution and the camera path. I finally figured it out and wanted to possibly help others who might find this thread in search of an answer with a more detailed description:
If you want the Camera to move while an animiation is running, you need to define a camera path using keyframes under view - visulization - create animation
At the same time, this 'animation' contains the resolution setting. When you later export a movie using file - export - mpeg (or animated tiff or what ever) this animation will be selectable under camera path. If you select the standard fixed camera, it will not use the resolution settings from the create animation and export in the standard shitty resolution.
Or maybe my NX is just broken. Anyway, that's the only way I was able to export anything in 1920x1080.
Oh, and to turn the image based lighting off, I had to go under: view - studio task - studio - advanced lights - visual effects settings
