Ansys joining two components
hi all
I'm trying to join a cuboid and a hollow cylinder together. The cuboid is to go on the outside of the cylinder on top on one of the ends, however I'm not sure what to use to join them.
The cylinder and cuboid are different materials. The cuboid is much stiffer and denser
The cuboid has a cross section touching the cylinder of 0.01*0.01
The outer diameter of the cylinder is .20
My next step is modal analysis once i have found how to do this...
any help greatly appreciated
