NXopen - How to move complete DatumCsys to new Layer
How can I move a complete DatumCsys - 3 DatumPlanes, 3 DatumAxis, 1 Point and 1 CSys to a new Layer with a VisualBasic Script?
I have a Script for that, but it does not move the Point and the Csys of the DatumCsys to the new Layer.
Here is the Code I used:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Features
Imports NXOpen.Utilities
Imports NXOpen.UF
Module ChangeDatums
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim ufs As UFSession = UFSession.GetUFSession()
Dim lw As ListingWindow = theSession.ListingWindow
Dim Layno As Integer
Layno = 41
Dim displayModification1 As DisplayModification
displayModification1 = theSession.DisplayManager.NewDisplayModification()
Dim objArray(0) As DisplayableObject
For Each ksobj As DisplayableObject In workPart.Datums
Dim ks_feat As NXOpen.Tag = NXOpen.Tag.Null
ufs.Modl.AskObjectFeat(ksobj.Tag, ks_feat)
If ks_feat <> NXOpen.Tag.Null Then
Dim datumfeat As NXOpen.Features.Feature = NXOpen.Utilities.NXObjectManager.Get(ks_feat)
If datumfeat.FeatureType.StartsWith("DATUM_CSYS") Then
objArray(0) = ksobj
workPart.Layers.MoveDisplayableObjects(Layno, objArray)
End If
End If
Next
End Sub
End Module
Can anyone help me with that problem??
With best Regards!
RE: NXopen - How to move complete DatumCsys to new Layer
Below is the proper code:
Dim csys_tag As Tag
Dim origin_tag As Tag
Dim daxes As Tag()
Dim dplanes As Tag()
ufs.Modl.AskDatumCsysComponents(feat.Tag, csys_tag, origin_tag, daxes, dplanes)
ufs.Obj.SetLayer(origin_tag, layer)
ufs.Obj.SetLayer(csys_tag, layer)
For Each thisObj As NXOpen.Tag In daxes
ufs.Obj.SetLayer(thisObj, layer)
Next
For Each thisObj As NXOpen.Tag In dplanes
Next
Koutilya
Hi Koutilya,
It doesn´t work. I have changed my to to this:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module ChangeDatums
Sub Main()
Layno = 41
For Each obj As DisplayableObject In workPart.Datums
Dim feat_tag As Tag
Dim csys_tag As Tag
Dim daxes As Tag()
ufs.Modl.AskDatumCsysComponents(feat_tag, csys_tag, origin_tag, daxes, dplanes)
ufs.Obj.SetLayer(origin_tag, Layno)
ufs.Obj.SetLayer(csys_tag, Layno)
ufs.Obj.SetLayer(thisObj, Layno)
Next
Next
Next
End Sub
End Module
Now I get the error:
System.Runtime.InteropServices.SEHException: One external Component has one Exception
by NXOpen.UF.UFModl._AskDatumCsysComponents(Tag datum_csys_tag, Tag& csys_tag, Tag& origin, Tag* daxes, Tag* dplanes)
by NXOpen.UF.UFModl.AskDatumCsysComponents(Tag datum_csys_tag, Tag& csys_tag, Tag& origin, Tag[]& daxes, Tag[]& dplanes)
by ChangeDatums.Main() in C:\Users\xxxxxxx\AppData\Local\Teamcenter\TMP\tc\NXJournals7288\journal.vb:Zeile 57.
I Have changed "...AskDatumCsysComponents(feat.tag..." to "...AskDatumCsysComponents(feat_tag..." couse i get some message, that "feat" was not declared. So I also habe declared "Dim feat_tag As Tag".
Michael
Here is some working code:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module ChangeDatums
    Sub Main()
        Const Layno As Integer = 41
        For Each myFeature As Feature In workPart.Features
            If TypeOf (myFeature) Is DatumCsys Then
                'uncomment the following If block to skip internal features
                'If myFeature.IsInternal Then
                '    Continue For
                'End If
                Dim csys_tag As Tag
                Dim daxes As Tag()
                ufs.Modl.AskDatumCsysComponents(myFeature.Tag, csys_tag, origin_tag, daxes, dplanes)
                Next
                Next
            End If
        Next
    End Sub
End Module
www.nxjournaling.com
Alternately, here is a version that doesn't use the UF functions.
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Const newLayer As Integer = 41
        For Each myFeature As Feature In workPart.Features.GetFeatures()
		'uncomment following If block to skip internal features
                '    Continue For
                'End If
                Dim DBuilder As DatumCsysBuilder
                DBuilder = workPart.Features.CreateDatumCsysBuilder(myFeature)
                Dim DCObj() As NXObject = DBuilder.GetCommittedObjects
                For Each temp As DisplayableObject In DCObj
                    temp.Layer = newLayer
                    temp.RedisplayObject()
                Next
                DBuilder.Destroy()
                Dim updateMark As Session.UndoMarkId
                updateMark = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "update")
                Try
                    theSession.UpdateManager.LogForUpdate(myFeature)
                    theSession.UpdateManager.DoUpdate(updateMark)
                Catch ex As Exception
                End Try
            End If
        Next
    End Sub
End Module
Hi cowski,
both codes works fine!
Thank you - It was very helpfull!
Also best regards to Koutilya.
Michael
