associative mass in drafting by using expression
hi,
can anyone tell me how can i associate mass from model to drafting . i tried with help of previous thread posted related to this by using 'ug_setpartattrvalue("weight",format("%f kg",mass))' but this work in metric part only when i use same formula for inches the value comes in attribute not right.
Thank u
ranjit
RE: associative mass in drafting by using expression
ranjitp,
What version of NX are you using? This gets a bit easier with NX 8 or later...
www.nxjournaling.com
using NX 7.5
Are you using teamcenter? If you are, you can set up a compound property that will work.
sam can u explain how can i set compound property
thank u
ranjit
