ARV - Automatic Recirculation Valve
Dear Gents,
Can anyone tell me what is disadvantage of using ARV especially for large pumps? for example pump with discharge nozzle 18", capacity 1525 m3/hr, head 56.45 m, service is HOT WATER CIRCULATION PUMP.
Since my end user refuse to use ARV for big pumps
Really appreciate for your help
Thank you
Thank you
RE: ARV - Automatic Recirculation Valve
Due to the construction,there are quite significant pressure losses in the ARV. For an application of such high capacity, the energy loss in the ARV even when is on by passing will be be significant.
Also, thank you very much for your explanation, really appreciate
