Breakaway Bolt Design
I am currently working on a breakaway Bolt Design. Ideally the first head of the bolt will break off at 45 ft-lbs. How can I calculate when the head will break off, assuming I know the neck down diameter that will break.
RE: Breakaway Bolt Design
If your tests came back with a range of +-2 lbs and your requirement is +-50 lbs you may be good. But if your requirement range is +-5 lbs you will need more samples.
I have done these kind of fixings in the past, the formula you've quoted is for the torsional stresses in the elastic region, the formula I would use is the one that gives the plaits stress for the whole cross section ie:- 4/3 * T.
Then I would do some practical tests and adjust my bolt groove to allow for strain hardening etc.
It's worked well for me in the past.
Quando Omni Flunkus Moritati
rb1957
is so the customer can just tighten them till the head breaks off, makes it dummy proof.
http://www.lisi-aerospace.com/products/fasteners/e...
