Bolted and Welded Joints
I'm studying for my professional engineering exam and came across a problem that was never really covered in my courses in school. I was wondering if I could get some input from some people.
Design a bolted joint to attach a suitable american standard steel channel at an 18 degree angle to store a bundle (16) of 8x8x1/2 x 26 feet long square structural tubing. An identical member 16 feet away supports the other end of the bundle which can vary off center by two feet. The W18X55 vertical members and the channels are made from ASTM A242 steel,. Specify the number of bolts, pattern, material grade, diameter, length, and maximum torque.
Additionally, the same problem except a welded joint instead of a bolted joint. Specify the minimum weld pattern, the type of electrode to be used, and the size of the weld.
Thanks for any help!
RE: Bolted and Welded Joints
Cheers
Greg Locock
you're right ... how wide to make it ? (ie the distance between the columns) ... well, how wide do you want to make it ? certainly there's a minimum ... and you might think how easy? it might be to stack 4" tubes 8 high if it was easy to the top tube to roll off ??
Quando Omni Flunkus Moritati
