Choose the ends of a small valve
Good afternoon,
I'm busy with some small modifications on existing pipelines designed according ASME.
1 of them contains the installation of a small valve <1" as drain on a Flare line.
The process engineer wants a flanged valve but the current pipe spec tells me to install a SW valve.
Is there any reference to an ASME code "rule" that you can choose the right end by fluid code/pressure/temperature?
It is a modification so why don't deviate the pipe spec, if it's off course acceptable.
Kind Regards,
Ruud
Kind Regards,
Ruud
RE: Choose the ends of a small valve
To deviate from the piping spec you would need to revisit the philosophy behind it, so probably just easier to install a valve with SW ends.
Cheers,
John
