Welding 4130 with 100K Min Yield Strength
We've been welding 4130 steel with 75 ksi minimum yield for sour service oil and gas applications quite successfully for a while. We're now looking at welding 4130 steel with 100 ksi minimum yield for a standard service oil and gas application. The standard service application has no H2S, so we don't need to meet NACE MR0175, but we still want to PWHT to relieve the residual stresses from welding. We need to maintain the 100 ksi minimum yield strength in the weld and base metal after welding and PWHT.
We're planning on using E12018-M filler metal in order to hit the required yield strength. Most of the filler metal data sheets that I've found for E12018-M don't give a recommended PWHT. Is E12018-M suitable for PWHT? If so, what is the lowest suitable temperature? (We need to stay below the tempering temperature of the steel).
Can anyone share any experience they've had welding 4130 with 100 ksi min yield?
Is there a similar alloy (such as 4330 or 8620) that is better for welding when 100 ksi min yield is required?
RE: Welding 4130 with 100K Min Yield Strength
Try and run a coupon and evaluate the mechanical properties. If your tempering temperature is too high you will soften (lower the strength) the surrounding 4130 base material. This is why I use 50 deg F below the original tempering temperature.
