ASME code section II Part A Ordering Information
Dear Forum member,
I have 1 queries about the ordering information as per asme II
when i order a pipe (SA 106 Gr.B)
Under ASME II Part A (3.1.12) End Use of material.
Does this clause means that i have to state the reason i buy the pipe in my ordering information?
Thanks in advance for reply.
wcw
wcw
RE: ASME code section II Part A Ordering Information
Do you mean that i have to tell my supplier the use of the pipe after i purchase it?
Example of my material requisition form:
PIPE DN300 SCH40 X 550MM (SEAMLESS )
SPEC: SA106 GR.B
ACCEPTABLE ASTM ED: A106 GRB 88a THROUGH 08
HOT FINISHED
O.D AND I.D VARIANCE < 1%
HYDROSTATIC TEST ACCORDING WITH SPECIFICATION
A530/530M OR 13.3 OF MENTIONED SPECIFICATION.
END USE OF MATERIAL: SHELL
Do i order the material according to asme code?
Cheers
wcw
