Transformer Pad
Transformer Pad
We're about to design a transformer pad we're a first timer in designing on this kind. Can anyone tell us how? and is there any useful article we can read? thanks.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Transformer Pad
You’ve given way to much important design info. The one in my front yard is molded fiberglas, with a hole in the middle for the buried cables to pass through. Then they just plunk the transformer down on it, make the connections and lock the lid. Shouldn’t involve more than a week of serious Structural Engineering.
RE: Transformer Pad
RE: Transformer Pad
RE: Transformer Pad
That is one hell of a curve ball.
Jolougarcia,
Please give us some idea of what you are designing, "transformer pad" means very little to us. is this s concrete slab, is it on ground or??? does it have feet or is it on a sled?
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
RE: Transformer Pad
RE: Transformer Pad
RE: Transformer Pad
Agree with others, if it is a slab it is all just a slab design and not too sure what else there is to it. Typical loads and geometric requirements should just be worked out but there is not too much. I would talk to your transformer manufacturer for their typicals and what they like to see.
RE: Transformer Pad
RE: Transformer Pad
1) Ask a vague, open ended question to a website visited by a lot of experienced engineers who have very little patience for vague, open ended questions.
2) Wait for the fun to ensue!
RE: Transformer Pad
Maine EIT, Civil/Structural.
RE: Transformer Pad
I was pulling your leg, in the hopes of getting you to think a little. You do have to use some engineering experience and judgement to design almost anything meaningful and useful to the world. And, if you ask your question on a forum, the way you did, there are many answers, you have to give use some clues if you want meaningful answers. We can’t see it from here. Talk with the transformer manufacturer about what they expect in the way of a foundation. What size is it and what does it weigh in operation? What are the soil conditions? Is this a large transformer at a power plant, a couple hundred tons maybe; a smaller transformer at a sub-station? The one in my front yard steps down the voltage from a main power line and serves six houses.
RE: Transformer Pad
http://www.jensenprecast.com/Electrical/Pads-p4250...
RE: Transformer Pad
https://www.youtube.com/watch?v=Gx8KJ8cu614
RE: Transformer Pad
They can be small 'plastic' pad mounted to very large ones. One transformer yard I did had four 400,000 lb transformers with 24,000 L of coolant oil each. It was supported on a structured slab with 6 auger piles and had containment.
Dik
RE: Transformer Pad
"Now" you did it!
Gee, you actually asked how big the transformer was, whether or not it was filled with oil, and whether or not it needed a oil-soak leak reservoir! Cripes. You'd think any of "that" was important or something. /sarchasm. 8<)
By the way.
Fire stop/fire block needed between the transformer and adjacent components?
What electrical requirements for standoff-distance, cable supports and cable tower foundations?
Movement railways or guides to roll the transformer?
What electric standoff/insulation distances do you need?
How are you going to get the rainwater/floodwater drained out of the oil-seep reservoir?
How are you supporting the fire prevention spray lines needed around the transformer? (I had to do that "little" job one time - hard when all you have is a 8 inch curb to mount a 40 foot pole.)
RE: Transformer Pad
RE: Transformer Pad
Fire barriers are another neat problem...
IFRs... I have some time to kill... but, not much... need more info... many little pads, it's ok to have some movement... and they are just concrete pads without foundations...
Dik
RE: Transformer Pad
The present IEEE 693 code favors embedded anchorage, but many transformer buyers are using post installed anchors. Some require that the anchors be undercut and some require that there can be no tension in the anchor - which may mean that the transformer manufacture has to spread out the anchor spacing.
Good luck.
RE: Transformer Pad
--Winston S. Churchill
RE: Transformer Pad
Dik
RE: Transformer Pad
