Undoing "feature dimension" and "show DOF" ??
Hi.
When you do
Edit -> Feature -> Feature Dimension.
Then, you can see the dimensions of the body in 3D.
How do you get rid of these dimensions?
And if you do
Assembly -> Component Position -> Show Degrees of Freedom
Then you can see several arrows indicating the DOF of the body.
Again, how can I disable or get rid of those arrows?
I know I can use the Ctrl+Z shortcut, but only if it was the last thing I did.
RE: Undoing "feature dimension" and "show DOF" ??
Refresh the view (shortcut: F5).
www.nxjournaling.com
You do realize of course that while those dimensions are still displayed, even if you've already left the original Edit -> Feature Dimension dialog and you have not yet, as cowski has suggested, done a 'Refresh' to get rid of their display, that if you double-clicked one of these dimensions that you will then be able to edit the parameters of the feature without having to do anything special.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
