Piping classes
Piping classes
Piping classes
Hello everybody !
A quick question as I cannot figure it out by myself...
One of my piping classes is for water, it is a carbon steel 600 lbs rating with a CA of 1,27 mm.
Material is as API 5L grade B.
My Temp / pressure couples are as follows :
Pressure (bar) : 102 102 92.7
Temp (°C) : -29 37 100
How can I know if this piping class will do for a pipe that needs (for calcul conditions) : 100 bar / 80°C ?
Thank you !
Daniel
RE: Piping classes
Look up the flange rating at Max Temp -- that should be the limiting factor.
RE: Piping classes
Exactly what Duwe6 said.
RE: Piping classes
Thank you, I looked up ASME B.16-5 and everything was there !
