nx 8.5 pmi's in view from part.
I want to do a view from part in a assembley drawing, using a view from one of its components containing PMIs.
I found a workaround by switching the ANT Icon with a sheet from the component to reference set entire part.
Is there a setting to force view from part to refence set entire part, cause of the PMIs?
sorry new in NX
regards
Erwin
RE: nx 8.5 pmi's in view from part.
In the drawing you will also need edit the View Style setting to inherit the PMI from the model (Inherit PMI tab).
Mike
