Overall heat tr. coef. from measurements, "quick" procedure with mistereous factor
I found this russian norm extract where a "quick" procedure for overall heat transfer coeficient (K in the document) stimation in heated cabins is given.
Basically it says:
- set up some kW of heaters, and internal and external T sensors.
- let wait about 1.5-2h to reach what it calls "regular heating mode of the 2th kind", this time is called th
- then take mean Tª jump (internal-external) for these times:
time = th, dTh
time = th + t1, dT1, t1 about 30 minutes
time = th + t2 (where t2 = 2t1),dT2
Total test time about 3,5 hours.
-then with the power, and effective cabin area F it says:
K = (Q/F) (2dT1 - dT2 - dTH) / (dT1^2 - dT2 - dTH)
Anybody have an idea about from where it comes that strange Temp factor?.
Probably I miss something because I would just use the last time.
K = (Q/F) (1/dT2)
Basically it says:
time = th, dTh
K = (Q/F) (1/dT2)
RE: Overall heat tr. coef. from measurements, "quick" procedure with mistereous factor
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
