Disappearing Projection
Hi.
I have a problem I have never encountered before. I have a sketch that I am projecting onto some freeform surfaces. It shows up as a yellow projection, indicating all is well. But when I click OK, it does not render. I know it's there, because I can click on its feature, and it appears in red as long as it is selected. It is not because the projection color is wrong, because I have other projected lines onto those same surfaces that show up just fine.
Strange.
RE: Disappearing Projection
Oh...There are no warning messages either, and the feature in the tree is not red (so no regen failure as far as Creo is concerned).
OK...I just deleted the projection and started again. This time it came out fine. I guess the original one was corrupted somehow.
