Foundation design-Basement level
Please see the attached sketch. Its a 120x80 building with a single story+basement. SDC=B, IBC 06.
The question I have is about the lateral/seismic load I have to design the foundation for. Do I have to take into account the seismic load from the floor and basement as well?
RE: Foundation design-Basement level
This depends on your code, but generally no. In very high seismic situations some codes will require an out-of-plain check for the wall itself to take the load without failling. In-plain loads on the basement wall are taken through compressive strutting to the soil retained on the far face of the opposing return wall. I've not seen a code that requires a check of these forces unless you have a walk-out type foundation, but then this is not a basement per say.
Translating:
Quote (CELinOttawa)
"out-of-plain, In-plain loads, and per say."
Canuck speak for: Out-of-plane, in-plane, and per se.
smile
Hahahaha... Nice one Ingenuity... We spell is "plane" too, it was just very late, I was tired.
The baby was crying! My mind was on "off"!
Insert additional excuses in proportion to massive embarrassment. *smiles*
You can use the top of the concrete foundation as a seismic base.
Mike McCann
MMC Engineering
