Concentrated Brine Thermal and Physical Properties
I am seeking information on a NACL concentrated brine solution . Density, viscosity, vapour pressure & bulk modulus vs. temperature. Properties are required for a fluid with 25% by weight salt.ie density ~ 1200kg/m3. Data in SI Units preferred.
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
